fstrydom
Aug 03, 2018Aspirant
Readynas NV+ Stuck at Quota check
Hi All. My Readynas NV+ experienced a power interruption. When I turned it on afterwards, it got stuck at "Quota check 11.1%". I was not able to connect with Raidar at that point. During startup I noticed that Disk 2 LED flashed a few times, then solid. My assumption was that disk 2 is failing which led me to remove disk 2. I powered up without disk 2, LED for disk 2 was flashing as there were no disk 2 present, but then it got stuck at the same place again. "Quota check 11.1%". After reading older forum messages showing the same symptoms I thought it will start up fine without disk 2. I then put disk 2 back and turned it on. This time it displayed "disk 2 sync" then "quota check", which went up to 11.1% again an FROZE...again. Now i have a bit of a situation. Any suggestions?
Did you try using the boot menu option to skip the volume check?
See pages 23-24 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
- fstrydomAspirantHi. Thank you for the reply. I have noticed it in the manual, but have not tried it yet. I was a bit cautious about the warning that goes with it. "Use this option to skip
the scan and let the system boot. Use this boot mode only if instructed to do so by a
NETGEAR technical support representative. Otherwise, you might lose data". I guess I will have to take the risk and do it. Have you had much experience with this option?
