MPF_SR
Jan 09, 2023Aspirant
ReadyNAS NV+ Stuck on booting
Let me start by saying that I’ve done a poor job of backing up my system, I'm trying to get the system up so that I can at least get some of my files off of there. After a power supply failure on...
MPF_SR
Jan 11, 2023Aspirant
I'm sorry, I know these are very basic questions but it's been over 17 years since I worked with Linux, do I use SSH like Telnet?
Is there a process that I need to start on the ReadyNAS, as I've tried using SSH and it doesn't connect.
Also tonight when I started support mode the vgscan command not found but it worked last night
Best regards
Jan 11, 2023Guru - Experienced User
MPF_SR wrote:Is there a process that I need to start on the ReadyNAS, as I've tried using SSH and it doesn't connect.
There is an add-on you need to install - the first one here:
Yes, but log in as root, and use the NAS admin password.
Did you chroot?
- MPF_SRJan 12, 2023Aspirant
I finally placed my orginal drives back in.
Here's the log file, I know that i need to free up some space.
Should I truncate both the kern.log and syslog?
7.5M /var/log/frontview
767M /var/log/kern.log
16k /var/log/ksymoops
14M /var/log/messages
0 /var/log/netatalk.log.old
16k /var/log/ntpstats
16k /var/log/raidiator_version
400k /var/log/samba
0 /var/log/slimserver.log
16k /var/log/squeezecenter
769M /var/log/syslog
16k /var/log/user.log
1.6G totalBest regards
- MPF_SRJan 22, 2023Aspirant
Thank you StephenB for your assistance.
After reading through a lot of the small issues in the community, many of us can't figure out how to mount the USB to be able to copy.
To resolve my issue I cloned the drives and I did an OS reinstall.
I am backing up the data and working on a better DR plan.
Thanks again, StephenB.
Would the 4 to 6 upgrade work on the NV+?
