MPF_SR
Jan 09, 2023Aspirant
ReadyNAS NV+ Stuck on booting
Let me start by saying that I’ve done a poor job of backing up my system, I'm trying to get the system up so that I can at least get some of my files off of there. After a power supply failure on...
Jan 13, 2023Guru - Experienced User
MPF_SR wrote:Here's the log file, I know that i need to free up some space.
Should I truncate both the kern.log and syslog?
Yes, I recommend doing that - you need the OS partition space.
MPF_SR
Jan 22, 2023Aspirant
Thank you StephenB for your assistance.
After reading through a lot of the small issues in the community, many of us can't figure out how to mount the USB to be able to copy.
To resolve my issue I cloned the drives and I did an OS reinstall.
I am backing up the data and working on a better DR plan.
- MPF_SRJan 22, 2023Aspirant
Thanks again, StephenB.
Would the 4 to 6 upgrade work on the NV+?
