mcpeterc
Nov 28, 2013Aspirant
ReadyNAS NVX - transmission 2.82 not starting
Hi friends. I have been using transmission addon since forever. I have never had problems until I upgraded from version 2.7x to 2.82. After this update the addon wont start. I have a copy of my se...
Abstract
Jan 12, 2014Aspirant
Hello everyone,
I have an Ultra 4 Plus running 4.2.25 and I cannot get Transmission to work. I had 2.80 working at one point, but after upgrading to 2.82 I always got the "Transmission service failed to start" error.
I tried to reverting back to 2.80 to see if that would fix things ... didn't help, same error. I also tried the 2.83 linked in this thread but no dice.
my settings.json file is shown below
Thanks in advance
Thanks in advance
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 2,
"dht-enabled": true,
"download-dir": “/multimedia/BitTorrent",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 0,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": “/multimedia/BitTorrent/Incomplete",
"incomplete-dir-enabled": false,
"lpd-enabled": false,
"message-level": 2,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 200,
"peer-limit-per-torrent": 50,
"peer-port": 51450,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"pidfile": "/var/run/transmission-daemon.pid",
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": “password1",
"rpc-port": 8181,
"rpc-url": "/transmission/",
"rpc-username": "admin",
"rpc-whitelist": “*”,
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/c/addons-config/Transmission/email_alert",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": true
