kamanwu's avatar
kamanwu
ReadyNas Pro 4, should I update to 6.10.2? (current version is 6.9.4)
I updated my Pro 4 from old OS to OS6 (6.9.4) about 9 months ago.  So far so good. I did not see any problems.   I just realized that the lastest version is 6.10.2 now.   Should I do the upgrade?  ...
  • Sandshark's avatar
    Dec 16, 2019
    The "Long Term Support" version of the OS is 6.9.5, hotfix 1.  Well, maybe it's 6.9.6, but that's ever been put in the update server, as far as I can tell.  The release notes for 6.10.2 are here: ReadyNAS-OS-6-Software-Version-6-10-2 and you can find similar ones for 6.10.0 and 6.10.1.
    I thought I was ready to go with 6.10.x on my legacy systems when it was found that there was a repository problem killing a lot of apps.  With such a huge mistake made and only noticed by those outside Netgear, I decided it was not ready for prime time.  I'm still runing 6.9.5, and it seems rock solid.
ProSupport for Business
