Chuck_B
Oct 13, 2019Follower
Readynas Pro RNDP6310-100NAS - Power Supply
Power Supply is bad for Readynas Pro RNDP6310-100NAS. Looking for options to see if I can buy another PSU or is there a new Readynas that would support my disk I could buy. Thanks
Oct 13, 2019Guru - Experienced User
It is possible to purchase and install your own PSU. Sandshark often gives help here to folks looking to do that.
You can temporarily mount your disks in a new x86 ReadyNAS so you can offload data. But you will need to reformat them after you do that. https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
