ForbesofEllon
Mar 16, 2022Aspirant
ReadyNas Pro2 can no longer access admin page
Today I tried to access the Admin page and got a message saying that my browser did not support the protocol of the page I was trying to reach. Checked on Netgear website to find that either my brows...
- Mar 16, 2022
If you do decide to convert the Pro 2, then you should increase the RAM to 2 GB before you begin. Shipping OS-6 NAS have at least 2 GB of RAM, your NAS only has 1 GB. Several folks have run into out-of-memory conditions after conversion. Upgrading the RAM is inexpensive (memory can be found for less than $25 USD), and is simple to do. PC3-10600 (204 PIN non-ECC SoDimm DDR3) memory should work.
The steps are:
(Optionally) make sure the latest BIOS is installed before you do the conversion. To do this you install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS. Do this after you backup the NAS. This isn't necessary, but if you do want to update the bios it is easiest to do it prior to conversion
Basic instructions for the conversion itself are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
Netgear won't provide paid support on a converted NAS, so that is one consideration. There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
ForbesofEllon
Thanks so much StephenB.
If you can point me at instructions to upgrade to OS 6 that would be great.
I have got used to my NAS being around I would hate to part company with it just yet.
Mar 16, 2022Guru - Experienced User
The steps are:
