STX1300MAN
Jul 03, 2017Star
ReadyNAS Remote Client Login Problems AGAIN
Since Friday 30th July we have been unable to login to ReadyNAS Remote using the WIndows Client. The message received is: A connection to the server could not be established; this error may occur...
JennC
Jul 10, 2017NETGEAR Employee Retired
Hello STX1300MAN,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
