mdgm-ntgr
Sep 11, 2012NETGEAR Employee Retired
ReadyNAS Remote for Mountain Lion now available
When you download the ML client from https://remote.readynas.com/download.html, please right click on the installer and click open. You will be able to use this to bypass the Gatekeeper check for now.
Danne1
Sep 13, 2012Aspirant
I have the same problem..
Properties -> (Grey'd out)
Shares > Does nothing
Manage -> Does nothing
ReadyDrop -> Does nothing
Log Out -> Works
Exit Works
I'm trying to connect to a ReadyNas Duo (RAIDiator 4.1.9)
Log Out -> Works
Exit Works
