mdgm-ntgr
Sep 11, 2012NETGEAR Employee Retired
ReadyNAS Remote for Mountain Lion now available
When you download the ML client from https://remote.readynas.com/download.html, please right click on the installer and click open. You will be able to use this to bypass the Gatekeeper check for now.
JordanLee
Sep 13, 2012Aspirant
Just realized, the picture NETGEAR uses for the tutorial is totally wrong. Maybe it's different for ML users but if you right click the bottom tray icon theres a connect to NAS option there. Took me a while to figure out as I was pulling my hair out. The remote system is also very finnicky, I had to set up an alternate USER ID because it said my password was wrong a billion times even though I reset it countless times.
