mdgm-ntgr
Sep 11, 2012NETGEAR Employee Retired
ReadyNAS Remote for Mountain Lion now available
When you download the ML client from https://remote.readynas.com/download.html, please right click on the installer and click open. You will be able to use this to bypass the Gatekeeper check for now.
mrichmon
Sep 14, 2012Aspirant
With a fresh install of ReadyNAS Remote v1.0.60 on Mountain Lion 10.7.1 the ReadyNAS client is unable to login to my ReadyDrop account. I created my ReadyDrop account by going directly to readydrop.netgear.com and creating an account via the web interface.
System logs show the following:
Note that recording a username and password in cleartext in the system logs is a very Bad Idea.
14/9/12 6:08:14.196 PM login[18339]: USER_PROCESS: 18339 ttys000
14/9/12 6:08:34.130 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:08:49.693 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:08:49.704 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:08:56.567 PM ReadyNAS Remote[18322]: NetworkManager: login:XXXXXXXX password:XXXXXXXX
14/9/12 6:08:56.568 PM ReadyNAS Remote[18322]: IsLoggedIn: NO
14/9/12 6:08:56.568 PM ReadyNAS Remote[18322]: ################## START FLASH!!!!
14/9/12 6:08:56.568 PM ReadyNAS Remote[18322]: called doLogin function in background, return YES
14/9/12 6:09:00.310 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:10:12.111 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:10:12.113 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:11:53.804 PM WindowServer[90]: Created shield window 0x1a42 for display 0x04280380
14/9/12 6:11:53.804 PM WindowServer[90]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
14/9/12 6:11:53.841 PM WindowServer[90]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
14/9/12 6:11:57.491 PM WindowServer[90]: handle_will_sleep_auth_and_shield_windows: no lock state data
14/9/12 6:16:42.754 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:17:15.410 PM ReadyNAS Remote[18322]: NetworkManager: login:XXXXXXX password:XXXXXXXX
14/9/12 6:17:15.410 PM ReadyNAS Remote[18322]: IsLoggedIn: NO
14/9/12 6:17:15.411 PM ReadyNAS Remote[18322]: ################## START FLASH!!!!
14/9/12 6:17:15.411 PM ReadyNAS Remote[18322]: called doLogin function in background, return YES
14/9/12 6:18:08.490 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:18:31.162 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
14/9/12 6:18:31.164 PM ReadyNAS Remote[18322]: ################## STOP FLASH!!!!
