mdgm-ntgr
Sep 11, 2012NETGEAR Employee Retired
ReadyNAS Remote for Mountain Lion now available
When you download the ML client from https://remote.readynas.com/download.html, please right click on the installer and click open. You will be able to use this to bypass the Gatekeeper check for now.
mdgm-ntgr
Sep 14, 2012NETGEAR Employee Retired
To use ReadyDROP you need a Duo/NV+ v2. You need Remote activated with access given to your Remote/ReadyDROP account and ReadyDROP enabled on the Duo/NV+ v2.
