mdgm-ntgr
Sep 11, 2012NETGEAR Employee Retired
ReadyNAS Remote for Mountain Lion now available
When you download the ML client from https://remote.readynas.com/download.html, please right click on the installer and click open. You will be able to use this to bypass the Gatekeeper check for now.
mdgm-ntgr
Oct 03, 2012NETGEAR Employee Retired
Have you tried trashing the Remote Application (move it from Applications folder into the Trash) then re-installing it to see if this fixes the issue?
