mdgm-ntgr
Sep 11, 2012NETGEAR Employee Retired
ReadyNAS Remote for Mountain Lion now available
When you download the ML client from https://remote.readynas.com/download.html, please right click on the installer and click open. You will be able to use this to bypass the Gatekeeper check for now.
chirpa
Oct 03, 2012Luminary
I've also noticed that upgrading the app rarely works, would always say login failed with the correct credentials. I have to move the old app to Trash and install fresh for it to work on new versions.
