mdgm-ntgr
Sep 11, 2012NETGEAR Employee Retired
ReadyNAS Remote for Mountain Lion now available
When you download the ML client from https://remote.readynas.com/download.html, please right click on the installer and click open. You will be able to use this to bypass the Gatekeeper check for now.
Crontons
Oct 04, 2012Aspirant
mdgm wrote: Have you tried trashing the Remote Application (move it from Applications folder into the Trash) then re-installing it to see if this fixes the issue?
Thanks for the reply. Yes, its actually a brand new unit and the only version I've installed of ReadyNAS Remote is the version 1.0.60. So its not like I had an old version installed and then upgraded. The results are the same. In order for me to be able to login successfully I have to re-install the application. It seems to make no difference if I move it to the trash before re-installing or not. Right after installing it works fine. If for some reason I shut down or reboot, then it never logs in again. Reinstall and it works fine...until a reboot of course.
