jwr11
Jun 12, 2010Aspirant
ReadyNAS remote install problems
Hello, I am unable to install the ReadyNAS remote software on a PC running Windows 7. I am guessing the problem is the leafnetworks adapter. I also tried doing a manual install of the adapter w...
MrAsker
Aug 25, 2010Tutor
I also have problems installing the ReadyNAS Remote client on Windows 7 x64. During the install it created copies of all my Network Adapters with a Netgear ending. These extra NICs could be Disabled but not Uninstalled.
Luckily the "Last Known Good" worked for me since I also got all my NICS hung by the install.
Anywho, I just installed and configured the Leaf Adapter manually and will do a Reboot to make sure it doesn't screw things up before I try the Install again.
