jwr11
Jun 12, 2010Aspirant
ReadyNAS remote install problems
Hello, I am unable to install the ReadyNAS remote software on a PC running Windows 7. I am guessing the problem is the leafnetworks adapter. I also tried doing a manual install of the adapter w...
steviep1
Dec 29, 2010Aspirant
I got a ReadyNAS Duo for Christmas with which I am gettingI am getting exactly the same issue (win 7 64). The installer causes a windows dialog to popup saying the the installer has stopped working. Clicking ok on the dialog appears to allow the installer to finish however the initialisation failed error code -3 comes up when I try to start ready nas remote. I also tried to install the leaf networks client but the same thing happens. I get an error code -3. I was able to install on my work PC which is also win 7 64. the only major difference I can think of is that this laptop has VMWare workstation installed which means there are already some virtual network interfaces created for it (no idea why that would be a problem though).
