jwr11
Jun 12, 2010Aspirant
ReadyNAS remote install problems
Hello, I am unable to install the ReadyNAS remote software on a PC running Windows 7. I am guessing the problem is the leafnetworks adapter. I also tried doing a manual install of the adapter w...
cateyed
May 28, 2011Aspirant
Hi all,
I stumbled across this post when I was having this problem also. I also had VMWare and Virtual Box installed. Since I don't need them, I have removed them, and the install completed successfully (even without a reboot).
Just thought I'd post in case this helps someone else.
Cateyed
Cateyed
