profexorgeek
Sep 19, 2013Follower
ReadyNas Remote Leaf Network errors
I need assistance getting ReadyNas remote to work correctly on my laptop. The laptop is a Macbook Pro running Windows 7 Professional x64 via Bootcamp. Here is what I've done so far:
- I enabled ReadyNas remote on my ReadyNas and installed the desktop app on my laptop according to the instructions here: https://www.readynas.com/?cat=52
- When installation completed I got the error message: "Probably you have an issue with Leaf Networks Adapter network adapter. You might resolve this issue..."
- I reinstalled the application and rebooted my laptop to make sure everything was set up correctly
- I made sure there was no gateway address set according to: http://www.readynas.com/forum/viewtopic.php?f=75&t=42500
- When I try replacing the .dll file mentioned in the above post, I get errors and the remote application won't load at all
- I tried custom-configuring the IP address. The custom IP address doesn't fix anything and appears to be reset every time the app is loaded
- I was going to try the manual reinstall of the Leaf Network drivers but I cannot find them anywhere. The link in one of the documents is dead.
- I checked my anti-virus program and added an exception for ReadyNas Remote, just in case.
- I have checked all of the configuration parameters I could find related to the Leaf Network adapter. It looks healthy in all regards but I continue to get the same errors
I am fairly proficient at configuring adapters and generally troubleshooting problems but I'm at a loss on this one. I would appreciate any help getting this up and running!
Hello cbrien,
ReadyNAS Remote on Win10 needs a BETA version. See ReadyNAS Remote BETA for Windows
- XxX_Cobra_XxXAspirantSame problem here :-(
- cbrienInitiate
Yet no respone from the readynas support wizards?
I was fine until I install Windows 10.
- JennCNETGEAR Employee Retired
Hello cbrien,
Hello profexorgeek,
Can you give us some screenshots during the installation?
Also when you ran the ReadyNAS Remote application, did you try right-clicking and choose Run as Administrator?
- cbrienInitiate
That beta app did the trick. Thanks
