Retired_Member
Jul 26, 2017readynas RND2000 duo V2 - Plex install
Hi Everyone, Newbie question so i apologise in advance if this has been covered already. I Recently got a 2nd hand ReadyNas DUO V2 for a good price, Ive installed a 2TB Nas drive and its read...
Retired_Member
Jul 26, 2017Hi Stephen,
Thanks for replying.
After many frustrating hours of searching i did kinda come to the conclusion that it was no longer supported.
If there is anyone out there with the correct version i would be so grateful if they could provide a link or Maybe Email it to me?
I have Plex Server running on my PC at the moment but wanted a full time solution - hence this cheap NAS drive.
I would rather not Mount the NAS as it will mean the PC running all the time which i dont really want to do.
Kind regards
Shep
ukbobboy
Sep 10, 2017Luminary
Hi Shep
I've just seen your post and so maybe too late to help you but I do have a copy of Plex that can run on your ReadyNAS Duo v2 because that is the very same hardware I run and my old version of Plex is running perfectly.
OK, the version of Plex you want is PlexMediaServer-0.9.16.6.1993-5089475-arm.bin, which is the final version of Plex made for the Duo v2.
If you still want this copy of PMS then drop me a post and link to the site where you want me to upload the copy.
Later.
UK Bob
- ihshaikhDec 25, 2017Tutor
Hi UK Bob
I would appreciate a copy of the PMS version for a ReadyNAs Duo v2.
Can send you a Dropbox link for you to upload.
- Roxy1Dec 30, 2017Apprentice
Hi Bob, I would like to give it a try on the NAS before resorting to a separate PC.
If you could share at
https://drive.google.com/drive/folders/1WjgnSq17cyc9eVGAFvctz11SvK0dVySm?usp=sharing
Thank you very much
- ukbobboyDec 31, 2017Luminary
Hi Roxy
Believe it or not, I sent the download site to you for PlexMediaServer-0.9.16.6.1993-5089475-arm.bin yesterday, i.e. 30th December, but it seems that something went wrong with this forum's reply facility.
Anyway, the site where you can download PMS from is as follows:-
Happy New Year and Happy Plexing
UK Bob
- Roxy1Dec 31, 2017Apprentice
Thanks Bob, and to you as well.
- thombeMar 05, 2018Apprentice
Hi (all)
I also have a now dusty Ready Nas Duo V2RAIDiator 5.3.13
I have been running Plex Server 0.9.16.4 (actually without any issues for a long time)
but I would like to make sure its as up to date as possible.
Is it worth updating to PlexMediaServer-0.9.16.6.1993-5089475-arm.bin as I haven't had any issues, and if so (maybe some extra features or something) ?
If there is a sensible reason to stick that last version on.. how do I actually do it ?
Thanks for the time reading this.
Ben
- mdgm-ntgrMar 05, 2018NETGEAR Employee Retired
If your Duo v2 ain't broke I wouldn't fix it. You're not going to gain a lot with such a small update. You can see what's changed look at the Plex Media Server Release Notes
However you're going to get further and further behind from what Plex has to offer now, so you may wish to plan to buy a new ReadyNAS that can run the latest Plex Media Server.
thanks and v true.
you may as well ignore, i've just done the update any. bit impatient.
so far no issues.
