Anonymous
Jul 26, 2017readynas RND2000 duo V2 - Plex install
Hi Everyone, Newbie question so i apologise in advance if this has been covered already. I Recently got a 2nd hand ReadyNas DUO V2 for a good price, Ive installed a 2TB Nas drive and its read...
ukbobboy
Jan 20, 2018Luminary
Hi BR
I think StephenB has made a small mistake, there is a fan made web-site where you can download Plex for your ReadyNAS Duo v1.0, running firmware 4.x.
The URL you want is as follows:-
Please note, I cannot make any recommendations or offer any kind of support because I have, personally, never downloaded any PMS software from this site myself, I just became aware of this fan site when Plex announced that they were no longer supporting or hosting any software below version 1.0.
Good Luck
UK Bob
bedlam1
Jan 20, 2018Prodigy
ukbobboy your link is for Raidiator 5.x (ARM)
There isn't one for Raidiator 4.x (SPARC)
- ukbobboyJan 20, 2018Luminary
Sorry Bedlam1
The PMS software for RN Duo V1 is for x86 cpu's only, I was totally unaware of this because my NAS runs an ARM 5.x cpu and I did not look any further.
UK Bob
PS. I originally thought that all RN Duo V1s had sparc cpu's.
- StephenBJan 20, 2018Guru - Experienced User
They do all have sparc CPUs - as do all ReadyNAS that run 4.1.x firmware. And plex is only available for arm and x86 platforms - not sparcs. The sparc ReadyNAS simply don't have the speed or memory, and they are running a very old version of linux. So my response above is completely correct.
I think you are confusing x86 legacy ReadyNAS (pro, nvx, ultra) with v1. The x86 legacy ReadyNAS run 4.2.x firmware.
As you know, even though plex runs on arm and x86, the plex folks dropped legacy ReadyNAS (v2s running 5.3.x and legacy x86 running 4.2.x) some time ago. So current plex builds are limited to OS 6 ReadyNAS.
Bedlam
You said, "I think you are confusing x86 legacy ReadyNAS (pro, nvx, ultra) with v1. The x86 legacy ReadyNAS run 4.2.x firmware". No I am not, if you check the website I posted the URL for, and scrolled upwards, you would see that it hosted PMS software for 4.x firmware but only x86 CPUs.
Here's the screen print I was going to post earlier:-
As stated before, I was unaware that this fan-site did not cater for Sparc CPUs, as my NAS uses Arm 5x and I did not check any further.
Good look in your continued search.
UK Bob
