paulgor
Apr 01, 2024Aspirant
ReadyNAS Ultra 6 ReadyDLNA / Squeezebox: install but disappear after reboot
Hi, all. I've had a ReadyNAS Ultra6 working with ReadyDLNA for years but it now only works when I manually upload the ReadyDLNA_1.1.4-x86.bin. When installed, the ReadyDLNA add-on does not show i...
Apr 01, 2024Guru - Experienced User
One option is to convert the NAS to OS-6. The first step would be to upgrade the amount of RAM to 2 GB or perhaps 4 GB. This is inexpensive. Converting to OS-6 does require reformatting the drives, so you would need to backup your files first.
Once converted, you could use the OS-6 DLNA service.
I am wondering what squeezebox has to do with your issue though.
paulgor
Cheers, Stephen.
I was wondering whether the issue had something to do with services not starting, hence my mention of Squeezebox.
UPnP is the same - I check the checkbox to start it but when the page refreshed, it doesn't stay checked.
Other issues include new media not being picked up by ReadyDLNA.
