pszilard
Sep 07, 2011Aspirant
ReadyNAS Ultra versus PRO and Egnyte
I know that Egnyte is only certifying the PRO range, but the Ultra seems very similarly speced. Question 1: Has anyone actually tried any ReadyNAS Ultra and Egnyte? Is it possible to load the Egnyt...
pszilard
Sep 08, 2011Aspirant
mdgm wrote: The Ultra 4 Plus has the same hardware as the Pro 4 and the Ultra 6 Plus has the same CPU as the Pro Business Edition. The Ultra 6 has the same CPU as the Pro 4, the Ultra 4 has a single-core CPU vs the dual-core in the Pro 4.
Personally I can't see why it wouldn't work, as long as Egnyte doesn't rely on the availability of business features. If there is an incompatibility it would be due to a software issue not a hardware one.
I tested the ELC add-on last year and it worked fine then with my Ultra 6.
Thanks for your post, mdgm. Where can I see a summary of the Business software features? Or can you give a list?
Thanks...
