pszilard
Sep 07, 2011Aspirant
ReadyNAS Ultra versus PRO and Egnyte
I know that Egnyte is only certifying the PRO range, but the Ultra seems very similarly speced. Question 1: Has anyone actually tried any ReadyNAS Ultra and Egnyte? Is it possible to load the Egnyt...
mdgm-ntgr
Sep 27, 2011NETGEAR Employee Retired
Pro 2 would be the recommended model. As far as I can tell it has exactly the same hardware as the Ultra 2 Plus. So as I said above the only reason why it might not work on an Ultra 2 Plus would be software issues (which I would think would be unlikely).
These models are supported: http://www.readynas.com/wp-content/uploads/2009/03/ReadyNAS_Comparison_Business.pdf
It is of course best to stick to supported models as if you have problems you'd want to be able to get support.
