Halsky
Feb 19, 2020Tutor
ReadyNase Duo v2
Hello. I have got ReadyNas Duo v2 RND2000-200EUS. I would like to insert there 2 HDD. Each HDD is 2TB capacity. I would like to set up RAID0 to get 4TB matrix. Is it possible?
Marc_V
Feb 19, 2020NETGEAR Employee Retired
Welcome to the Community!
RAID0 with 2 2TB disk is possible on the Duo V2 :) It can even take 4TB disks.
Note though that using RAID0 has no protection in case of failure.
HTH
Regards
Halsky
Feb 19, 2020Tutor
oki ... Thank you for answer Marc_V but could you tell me step by step how can I do this please?
I don't care about data protection in case of failure. This is my additional backup.
What I tried to do up to now:
I've putted 2 Hard Drives (2TB each) in case. Than I've downloaded RAIDar 4.3.8 (I've tried to do that by RAIDar 6.5 - the newest version but I read that it is better to use older version) and I've installed it. I've reset ReadyNas Duo V2 to factory settings.
Using software RAIDar 4.3.8 I choice Flexible Volume (Flex-RAID) level 0 option. But always after that I have one Volume with 1.8TB capacity.
How can I create 4TB matrix in one volume ?
