holsen1
Feb 06, 2022Aspirant
Reallocated Sector Count Increasing Daily
Hey All I've got an NV+ with 4 x 2TB drives in it. I'm getting daily Logs showing the reallocated sector count increasing on DIsk 4 which would seem to indicate it may be close to failing. My qu...
Feb 07, 2022Guru - Experienced User
holsen1 wrote:I've got an NV+ with 4 x 2TB drives in it.
The maximum disk size supported by the NV+ v1 (4.1.x firmware) is 2 TB. Larger drives won't work.
- holsen1Feb 08, 2022Aspirant
Beautiful Thanks!
Replaced the bad drive with SD Red Got 11 years out of the old Constellation.
Decided to replace the other 3 as well, 1 at a time. So Here's the question. Once I pull these other drives, is there a way to reformat them NTFS or exFat. Just plugged one into Windows and Disk Manager doesnt recognize it.
