Kish
Aug 06, 2011Aspirant
Removing NASMonitor 3.6.10 from my PRO?
How do I remove/uninstall NASMonitor 3.6.10 from my PRO, even after I tell FV to remove it?
- super_poussinVirtuosoit should be removed when you ask for remove in frontview
- KishAspirantYes. But, it does not get removed. So, how do I remove it?
- kervernAspirantup !
i have same probleme impossibilitie to remove it ! - mdgm-ntgrNETGEAR Employee RetiredHave you tried clearing your web browser cache (e.g. Temporary Internet Files)?
Do you have SSH access? - kervernAspiranti have no ssh access, and i know if there same problem, but my media drive is corrupt by many file with extension *.php that i can't delete......
poussin: au faite tu parle francais ou pas ?
