Bob94301
Jan 21, 2021Guide
Removing Readynas Remote AND Leaf Netwroks
I have a DUO that works flawlessly for me. However, in an odd click discovered ReadyNas Remote 1.6.5.18 no longer works. That's ok. But the questions are: If I remove ReadyNas Remote from control...
- Jan 22, 2021
It's been a long time since I had Remote installed on a PC - but I think uninstalling it there should remove the Leaf VPN as well.
Jan 22, 2021Guru - Experienced User
Bob94301 wrote:
If I remove ReadyNas Remote from control panel, will it also remove the Leaf Network adapter?
The VPN service will still be present in the system, but it only runs if Remote is running.
Bob94301 wrote:
If not, how to remove the Leaf Adapter?
You could do with SSH I guess. Not something I've felt the need to do, so I don't know if there are side effects if it is missing.
But obviously doing an OS reinstall, etc would just add it back.
Bob94301
Jan 22, 2021Guide
Thanks, but we must be talking about two different things. Leaf Networks runs in Windows and always runs regarless of whether ReadyNas Remote runs or not. Neiother of these are on the NAS.
