Bob94301
Jan 21, 2021Guide
Removing Readynas Remote AND Leaf Netwroks
I have a DUO that works flawlessly for me. However, in an odd click discovered ReadyNas Remote 1.6.5.18 no longer works. That's ok. But the questions are: If I remove ReadyNas Remote from control...
- Jan 22, 2021
It's been a long time since I had Remote installed on a PC - but I think uninstalling it there should remove the Leaf VPN as well.
Bob94301
Jan 22, 2021Guide
Thanks, but we must be talking about two different things. Leaf Networks runs in Windows and always runs regarless of whether ReadyNas Remote runs or not. Neiother of these are on the NAS.
Bob94301
Jan 22, 2021Guide
Ahhh, OK. There are two parts. One on the NAS and one as a Windows CLient. Its the windows clinet and Winodws Network Adapter I wish to remove.
- StephenBJan 22, 2021Guru - Experienced User
- Bob94301Jan 23, 2021Guide
Thanks. That's what I was hoping but I always like to check to be sure nothing else destabilizes. Especially since that was installed 8 or 9 years ago :)
Will likely try later this weekend.. I'll do a restore point just in case.
You were right. Clean uninstall of Leaf and Firewall port changes, etc with a simple ReadyNas remote uninstall. All good. Thanks.
