Bob94301
Jan 21, 2021Guide
Removing Readynas Remote AND Leaf Netwroks
I have a DUO that works flawlessly for me. However, in an odd click discovered ReadyNas Remote 1.6.5.18 no longer works. That's ok. But the questions are: If I remove ReadyNas Remote from control...
- Jan 22, 2021
It's been a long time since I had Remote installed on a PC - but I think uninstalling it there should remove the Leaf VPN as well.
Bob94301
Jan 22, 2021Guide
Ahhh, OK. There are two parts. One on the NAS and one as a Windows CLient. Its the windows clinet and Winodws Network Adapter I wish to remove.
Jan 22, 2021Guru - Experienced User
- Bob94301Jan 23, 2021Guide
Thanks. That's what I was hoping but I always like to check to be sure nothing else destabilizes. Especially since that was installed 8 or 9 years ago :)
Will likely try later this weekend.. I'll do a restore point just in case.
You were right. Clean uninstall of Leaf and Firewall port changes, etc with a simple ReadyNas remote uninstall. All good. Thanks.
