ephect
Oct 24, 2011Aspirant
replicate errors
ok we've had the replicate licences for a while now and at first it was erroring when trying to run a backup job both data and system. didnt worry too much as they weren't getting used until the site ...
arjoseph1
Oct 31, 2011Tutor
Disabling snapshots may be the best practice for the first backup as so much data will be transferred that the potential for the source’s snapshot buffer to run-out is high.
However, it is recommended to enable snapshots, if possible, as they will ensure a consistent backup if files are changing on the source when the backup is running.
You can disable snapshots for the first run of the job, then edit the job and re-enable snapshots for subsequent runs.
