TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open. assuming its possible, would love to see this a...
TeknoJnky
Feb 07, 2011Hero
mine was doing that for a while when I was having problems with 4.2.16 betas. A factory default finally fixed it :(
otherwise, check max memory in subsonic.sh if you have a large library you will need to increase until it stops crashing.
also, you can disable the auto-update search and it may stop crashing also.
and, you should not need to re-install, just click the checkbox off + save, then checkbox on + save, should restart service
