TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open. assuming its possible, would love to see this a...
TeknoJnky
Feb 07, 2011Hero
dcuellar wrote: How would I go about checking max memory?
you can ssh in and check webroot/subsonic/subsonic.sh
or browse to //nas/webroot/subsonic and open subsonic.sh with whatever notepad you use
look for the max memory line or something similar
How much memory should be allotted.
depends on the size of your library. My subsonic library is just over 1tb and needs about 800
I would recommend increasing it 100 at a time up to 800ish max until it stops crashing.
Subsonic is really the only app I use. If not that, then I use Airvideo and Skifta occasionally.
does not have anything to do with other applications
How do I disable auto-update?
log into the subsonic web page as admin, then under settings > search you can disable auto-update search index
If I do a factory default will I lose anything?
yes of course, you would have to backup all data, factory default, then restore data and reinstall any addons.
but if your running into memory problems, then you should adjust that, factory defaulting won't help if subsonic is running out of memory.
