TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open. assuming its possible, would love to see this a...
super_poussin
Feb 09, 2011Virtuoso
can you try :
Airvideo 1.2 all-in-one
(the all in one is the one I use at home
not shure m4a are supported ==> I think Airvideo for Linux alpha 4 did not support audio only files :(
I have include lame (I think it's not used by AirVideo) and Also faac
Skywalker:/c/webroot/AirVideo# ffmpeg
FFmpeg version UNKNOWN, Copyright (c) 2000-2010 Fabrice Bellard, et al.
built on May 5 2010 09:37:32 with gcc 4.4.1
configuration: --enable-pthreads --disable-shared --enable-static --enable-gpl --enable-libx264 --enable-libmp3lame --enable-libfaad --disable-decoder=aac
libavutil 50. 8. 0 / 50. 8. 0
libavcodec 52.52. 0 / 52.52. 0
libavformat 52.50. 0 / 52.50. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Skywalker:/c/webroot/AirVideo# faac --help
Freeware Advanced Audio Coder
FAAC 1.28
Usage: faac [options] infiles ...
Options:
-q <quality> Set quantizer quality.
-b <bitrate> Set average bitrate to x kbps. (ABR, lower quality mode)
-c <freq> Set the bandwidth in Hz. (default=automatic)
-o X Set output file to X (only for one input file)
-r Use RAW AAC output file.
-P Raw PCM input mode (default 44100Hz 16bit stereo).
-R Raw PCM input rate.
-B Raw PCM input sample size (8, 16 (default), 24 or 32bits).
-C Raw PCM input channels.
-X Raw PCM swap input bytes
-I <C,LF> Input channel config, default is 3,4 (Center third, LF fourth)
MP4 specific options:
-w Wrap AAC data in MP4 container. (default for *.mp4 and *.m4a)
-s Optimize MP4 container layout after encoding
--artist X Set artist to X
--writer X Set writer to X
--title X Set title to X
--genre X Set genre to X
--album X Set album to X
--compilation Set compilation
--track X Set track to X (number/total)
--disc X Set disc to X (number/total)
--year X Set year to X
--cover-art X Read cover art from file X
--comment X Set comment to X
Documentation:
--license Show the FAAC license.
--help Show this abbreviated help.
--long-help Show complete help.
More tips can be found in the audiocoding.com Knowledge Base at
<http://www.audiocoding.com/wiki/>
Skywalker:/c/webroot/AirVideo# ./ffmpeg -i /media/Videos/Be/be.m4a /media/Videos/Be/be.avi
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/media/Videos/Be/be.m4a':
Metadata:
major_brand : M4A
minor_version : 0
compatible_brands: M4A mp42isom
title : Be
author : Common
composer : Lonnie Lynn, Kanye West, Ceasar Frazier
album : Be
track : 1
date : 2005
encoder : iTunes v7.4.3.1, QuickTime 7.2
Duration: 00:02:24.26, start: 0.000000, bitrate: 129 kb/s
Stream #0.0(und): Audio: libfaad, 44100 Hz, 2 channels, s16, 128 kb/s
File '/media/Videos/Be/be.avi' already exists. Overwrite ? [y/N] y
Output #0, avi, to '/media/Videos/Be/be.avi':
Stream #0.0(und): Audio: mp2, 44100 Hz, 2 channels, s16, 64 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
size= 1267kB time=144.25 bitrate= 72.0kbits/s
video:0kB audio:1127kB global headers:0kB muxing overhead 12.445309%
