TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open. assuming its possible, would love to see this a...
TeknoJnky
Feb 10, 2011Hero
that should be more than plenty for 12k songs
did you disable the search index?
login as an admin, settings > search > automatically update index = never
if stops crashing, then its something related to search index (which is one of the reasons to increase memory, but 600 should be fine)
