TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open. assuming its possible, would love to see this a...
TeknoJnky
Feb 10, 2011Hero
I don't know, I had the same problems before too, but I don't know what fixed it, sorted started working on its own.
you could try uninstalling and then reinstalling 1.8, making sure the memory is set to 500 or 600ish
you can also check the subsonic.log file for any clues
