TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open. assuming its possible, would love to see this a...
super_poussin
Feb 13, 2011Virtuoso
dcuellar wrote:
super-poussin wrote:
restart it with button on front panel
I'm afraid it's a bigger issue than can be solved by doing that. My frontview won't save any settings and has disabled all of my shares. I'm on the phone now with Netgear support to see if we can figure this out. I'll let you know what happens.
As for the caching, I'll try that when I get it back up.
Did you figure out anything on the characters? I'm wondering if it has to do with the language setting in frontview. If I select English (ASCII) instead of Unicode will it allow me to see characters like "é"? Technojunky seems to be suffering from the same, others just may not realize it. I provided a link to the forum thread where they provide the solution, but the file I have to edit is not where it should be. I'm wondering if you could do the edit being that you know where the file should be.
to have é è à it should be better to use Frenche unicode rather than French ASCII
