TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open. assuming its possible, would love to see this a...
TeknoJnky
Mar 05, 2011Hero
strange, I was just checking video on subsonic after getting my nas all rebuilt, and no audio either.
the ffmpeg linked above appears to be same version installed with 1.8
I know I had it working before but don't remember if I had to change the strings.
using the default transcode strings, has anyone currently got audio working?
edit:
actually it does look like a different version, I forgot to chmod +x therefore it was running the default ffmpeg
full solution
audio should work now
@ s-p can the working ffmpeg be added to the next release or is there some thing that prevents that?
sauron:/c/webroot/subsonic# ffmpeg --help
FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-gpl --enable-pp --enable-pthreads --enable-vorbis --e nable-libogg --enable-a52 --enable-dts --enable-libgsm --enable-dc1394 --disable -debug --enable-shared --prefix=/usr
libavutil version: 0d.49.0.0
libavcodec version: 0d.51.11.0
libavformat version: 0d.50.5.0
built on Apr 26 2009 11:34:57, gcc: 4.1.2 20061115 (prerelease) (Debian 4.1.1- 21)
ffmpeg: missing argument for option '--help'
edit:
sauron:/c/webroot/subsonic# ./ffmpeg --version
FFmpeg version UNKNOWN, Copyright (c) 2000-2010 Fabrice Bellard, et al.
built on May 5 2010 09:37:32 with gcc 4.4.1
configuration: --enable-pthreads --disable-shared --enable-static --enable-gpl --enable-libx264 --enable-libmp3lame --enable-libfaad --disable-decoder=aac
libavutil 50. 8. 0 / 50. 8. 0
libavcodec 52.52. 0 / 52.52. 0
libavformat 52.50. 0 / 52.50. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
full solution
ssh in
wget http://www.readynas.com/contributed/super-poussin/ffmpeg
chmod +x ffmpeg
cp /usr/bin/ffmpeg /usr/bin/ffmpeg.bak
cp ffmpeg /usr/bin/ffmpeg
