ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the nas =( ... Anyone else who have the same issue ? And if i have it running and restart the nas it stops aswell =( this sucks
Well solved it by downgrading it back to 2.0
- acweb1AspirantI am also seeing this issue...
- super_poussinVirtuosodid you try the last beta ?
- gibxxiGuideYour probably already aware of this Super, but the add-on active light in Frontview doesn't stay lit when Subsonic is running (Latest Beta). Exactly the Opposite of transmission (Where the checkbox doesn't stay selected).
- acweb1AspirantYes I am using the latest beta v4.7.02
Thanks for your reply. - super_poussinVirtuoso
gibxxi wrote: Your probably already aware of this Super, but the add-on active light in Frontview doesn't stay lit when Subsonic is running (Latest Beta). Exactly the Opposite of transmission (Where the checkbox doesn't stay selected).
let me check why - ludwichAspirantAlso using the latest beta but it stops at the same time every morning 7.15. Thats when i used to have it to power up but nowadays its up all the time so i removed thoose settings but it still keeps stoping =(
- gibxxiGuideNo issues with the latest version for me. My library is only 10,000 tracks large though. A medium sized library compared to some others on here. You may want to edit the config files for Subsonic and increase it's memory allocation, that has been proven to increase stability for some. Or see if the scan is interfering with another operation that's occuring at the same time. Try scheduling the daily update to a different time of day and see if that causes it to not stop.
- greeeAspirantI have the same issue since I apply the last update (4.7 beta 2) on my readynas NVX
Please Super Poussin, can you do an update or patch ? - Ping1AspirantI have encountered the same problem after some adding and deleting files in my NAS two weeks ago. I have done many things trying to make it work again, turning it on and off for many times, reinstall it using either the 2.0 or 4.7 versions. They all did not work and it still crashed. Finally, I re-installed the subsonic 2.0, then updated it to 4.7 beta version. I could launch the page even the green light is not on. I disabled the automatic media re-scanning and I disabled the Podcast re-scanning button. I re-installed the ReadyNAS firmware by pressing the reset button with a clip and power on button for 5 seconds. The problem solved and subsonic won't crash anymore for the past 2 days. I hope that can solve the problem.
- greeeAspiranthello ping.
WAOU, it is quite a violent respond to a software bug.
I hope and wait for Super Poussin (please!!!) to find a softer way (patch or new release) ; even if it's a really annoying bug during holidays (when you especially want to listen to your music from a far distance from home). But maybe Super Poussin is also under the sun somewhere far away from his computer :)
