ludwich
Jun 26, 2012Aspirant
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the n...
gibxxi
Jul 10, 2012Guide
No issues with the latest version for me. My library is only 10,000 tracks large though. A medium sized library compared to some others on here. You may want to edit the config files for Subsonic and increase it's memory allocation, that has been proven to increase stability for some. Or see if the scan is interfering with another operation that's occuring at the same time. Try scheduling the daily update to a different time of day and see if that causes it to not stop.
