TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp
appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open.
assuming its possible, would love to see this available for x86 devices to stream directly from nas
- super_poussinVirtuoso
dcuellar wrote: Let me see if I understand the process here. You are basically porting subsonic to readynas, right? What happens when subsonic updates their app?
And what is the latest version for readynas?
I always try to follow my addons :)
Super-Poussin
If you like my add-ons please donate :) - dcuellarAspirantCool. I'll try it out when I get home tonight.
- dcuellarAspirantWhy is subsonic v 1.5 not posted in the original thread but it is posted here?
- dcuellarAspirantAny chance we can see an update for Subsonics v4.4?
- gibxxiGuide
dcuellar wrote: Any chance we can see an update for Subsonics v4.4?
+1
:) - super_poussinVirtuoso
gibxxi wrote: dcuellar wrote: Any chance we can see an update for Subsonics v4.4?
+1
Perhaps tomorrow :) if I have time
Super-Poussin
If you like my add-ons please donate :) - dcuellarAspirantI'm having an issue with the subsonic server where it will crash. It's almost a daily occurrence. I try to launch it from Frontview>Services>Installed Add-ons but it will say that it cannot connect to the server. The only way of fixing it is to reinstall the add-on in Frontview>Update>Local.
Anyone have any idea what is going on? I understand that it might be due to subsonic crashing, but there must be an easier way to start subsonic back up besides reinstalling it every time. - super_poussinVirtuoso
dcuellar wrote: I'm having an issue with the subsonic server where it will crash. It's almost a daily occurrence. I try to launch it from Frontview>Services>Installed Add-ons but it will say that it cannot connect to the server. The only way of fixing it is to reinstall the add-on in Frontview>Update>Local.
try to increase momory usuable by subsonic in subsonic.sh - mine was doing that for a while when I was having problems with 4.2.16 betas. A factory default finally fixed it :(
otherwise, check max memory in subsonic.sh if you have a large library you will need to increase until it stops crashing.
also, you can disable the auto-update search and it may stop crashing also.
and, you should not need to re-install, just click the checkbox off + save, then checkbox on + save, should restart service - dcuellarAspirantHow would I go about checking max memory? How much memory should be allotted. Subsonic is really the only app I use. If not that, then I use Airvideo and Skifta occasionally.
How do I disable auto-update?
If I do a factory default will I lose anything?
