TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp
appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open.
assuming its possible, would love to see this available for x86 devices to stream directly from nas
- super_poussinVirtuosodone
- super_poussinVirtuosoI think I have found a way to make it more stable
- thekillersAspirantSuper poussin, Penses-tu pouvoir l'adapter pour un RNDuo ?! J'utilise actuellement FirePlay, mais si la v4.3 de SubSonic possède un module pour la vidéo, c'est tout bonheur.
Merci ;) - Hi S-P, do you have FFMPEG included with the addon installer or is a part of readynas?
apparently the version installed does not support encoding to mp3
is there a way to get a newer version included or should it be safe to follow the directions @
http://ubuntuforums.org/showpost.php?p= ... tcount=360
more info @ http://www.activeobjects.no/subsonic/fo ... 9552#19552 - super_poussinVirtuosotry this ffmpeg version http://www.readynas.com/contributed/sup ... sin/ffmpeg
- thx, I get this tho
ffmpeg: error while loading shared libraries: libm.so.6: cannot open shared object file: No such file or directory
apt-get update > /dev/null; apt-get -y --force-yes --reinstall install libc6 libc6-amd64 > /dev/null - that worked super awesome, thanks super-poussin!
TeknoJnky wrote: that worked super awesome, thanks super-poussin!
de nada :)
I have a new version but can't upload it to server (67MB) :( - super_poussinVirtuoso
