TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp
appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open.
assuming its possible, would love to see this available for x86 devices to stream directly from nas
- solution is earlier in the thread @ viewtopic.php?f=61&t=45638&start=30#p283546
- strange, I was just checking video on subsonic after getting my nas all rebuilt, and no audio either.
the ffmpeg linked above appears to be same version installed with 1.8sauron:/c/webroot/subsonic# ffmpeg --help
FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-gpl --enable-pp --enable-pthreads --enable-vorbis --e nable-libogg --enable-a52 --enable-dts --enable-libgsm --enable-dc1394 --disable -debug --enable-shared --prefix=/usr
libavutil version: 0d.49.0.0
libavcodec version: 0d.51.11.0
libavformat version: 0d.50.5.0
built on Apr 26 2009 11:34:57, gcc: 4.1.2 20061115 (prerelease) (Debian 4.1.1- 21)
ffmpeg: missing argument for option '--help'
I know I had it working before but don't remember if I had to change the strings.
using the default transcode strings, has anyone currently got audio working?
edit:
actually it does look like a different version, I forgot to chmod +x therefore it was running the default ffmpegsauron:/c/webroot/subsonic# ./ffmpeg --version
FFmpeg version UNKNOWN, Copyright (c) 2000-2010 Fabrice Bellard, et al.
built on May 5 2010 09:37:32 with gcc 4.4.1
configuration: --enable-pthreads --disable-shared --enable-static --enable-gpl --enable-libx264 --enable-libmp3lame --enable-libfaad --disable-decoder=aac
libavutil 50. 8. 0 / 50. 8. 0
libavcodec 52.52. 0 / 52.52. 0
libavformat 52.50. 0 / 52.50. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
full solutionssh in
wget http://www.readynas.com/contributed/super-poussin/ffmpeg
chmod +x ffmpeg
cp /usr/bin/ffmpeg /usr/bin/ffmpeg.bak
cp ffmpeg /usr/bin/ffmpeg
audio should work now
@ s-p can the working ffmpeg be added to the next release or is there some thing that prevents that? - super_poussinVirtuoso1.9 will solve the issue :)
- ThotoTutorbtw, for anyone having issues with subsonic dying from time to time, if everything else failed, I posted a workaround script in this thread that will ensure Subsonic is running or restart it if needed on a regular basis.
Super-poussin said he will include it in the next release.
I hope this helps... - mfe_TutorHi,
i installed subsonic on my readynas DUO.
My java Version is:fes-a120d19nas:/var/subsonic# java --version
SableVM version 1.11.3
- compile date and time: 2005-04-16 09:50:59 UTC
- gcc version: 3.3.5 (Debian 1:3.3.5-12)
- 'real life brokenness' features enabled
- signal based exception detection
- copying garbage collection
- bidirectional object layout
- inline-threaded interpreter
I installed an old subsonic version (i think it was 2.7) and started it with ./subsonic.sh. After starting it the subsonic process is dieing and it writes into the log file:fes-a120d19nas:/var/subsonic# tail subsonic_sh.log
java.lang.UnsupportedClassVersionError
at java.lang.VMClassLoader.nativeDefineClass (VMClassLoader.java)
at java.lang.VMClassLoader.defineClass (VMClassLoader.java:94)
at java.lang.ClassLoader.defineClass (ClassLoader.java:673)
at java.security.SecureClassLoader.defineClass (SecureClassLoader.java:108)
at java.net.URLClassLoader.findClass (URLClassLoader.java:926)
at java.lang.ClassLoader.loadClass (ClassLoader.java:360)
at java.lang.ClassLoader$1.loadClass (ClassLoader.java:1285)
at java.lang.ClassLoader.loadClass (ClassLoader.java:304)
at java.lang.VirtualMachine.main (VirtualMachine.java:99)
Has anyone a idea why this error occours? Is this a java version issue? - you need an x86 device, duo/nv+ are not supported.
- mfe_TutorI installed java /subsonic by myself. I didnt installed the addon.
The posted error log seems to be an "to less memory issuse". :( - RedDeathAspirantAny chance that Subsonic 4.5 gets ported? Lots of new features. Thanks!
- super_poussinVirtuoso4.5 beta 2 is already available as addon . New version when back from vacation :)
