gibxxi
Nov 28, 2012Guide
[REQUEST] Maraschino UI (For XBMC)
Maraschino is a web style UI that runs on Python and can monitor multi-seat XBMC installs. It can also monitor SABNZBD, Sickbeard, CouchPotato and HeadPhones. Call it a central control panel for XBMC / NewsGroup apps.
Tried to install it manually, but as I don't really know what I'm doing in Linux, it wouldn't run / was unreachable. The install directions on their site specify Debian (which is what the ReadyNAS uses), but I couldn't get it to work.
The Add-on can update itself from the central GIT repository. I could get this running quite easy on my Windows PC, as I already have a working Python /Pywin install on there. That's not the point...
http://www.maraschinoproject.com/
- bbaraniecLuminary+1 thou it took me less then 5 min to run this on linux.
- gibxxiGuideI got it running eventually. Would seem that the custom port setting as set in the config file is only read if the DB doesn't exist. If the DB does exist, it uses the port setting from that. Mine was still set to the default, so had to delete the DB and set it up again, then change the port in the DB before attempting any updates that trigger a restart.
- Aug 31, 2022Retired_Member
