kcomprepair1
Jan 31, 2015Aspirant
RND2110 not able to create readynas remote account
Hi guys, I'm trying to setup an RND2110. The ReadyNAS Remote addon is installed, but when I go to create an account and send a confirmation email, it never sends (I've tried 3 different email domai...
kcomprepair1
Feb 12, 2015Aspirant
StephenB wrote: I agree that you are double-routing, not really bridging. I have a similar configuration (Verizon router with 192.168.x.x addresses in front of a R6300v2 with 10.x.x.x addresses). What I've done is forward the ports I am using from the Verizon router to the R6300v2, and then forward again in the R6300v2.
On the DNS server, you can only change the DNS server if the NAS is set to use a static address. Otherwise you need to change the DNS in one of the routers (which will change the default DNS server for all devices).
THanks to both of you again.
I have it setup so that the ATT router is DMZ'ing all traffic to the netgear. The nas is on a static ip but i'll look again for the DNS setting.
- Apr 16, 2020Retired_Member
