kcomprepair1
Jan 31, 2015Aspirant
RND2110 not able to create readynas remote account
Hi guys, I'm trying to setup an RND2110. The ReadyNAS Remote addon is installed, but when I go to create an account and send a confirmation email, it never sends (I've tried 3 different email domai...
Feb 12, 2015Guru - Experienced User
I started that way, but discovered connectivity issues - which were resolved when I forwarded the ports explicitly. Probably a bug in my edge Verizon router (an Actiontec in my case).
kcomprepair wrote: I have it setup so that the ATT router is DMZ'ing all traffic to the netgear.
Perhaps try connecting a laptop to the ATT router, and putting the laptop in the DMZ temporarily. Then see if the ports are all open.
Your ISP could also be blocking some ports (though I can't think of any reason to block 6300).
- Apr 16, 2020Retired_Member
