Silversurfer79
Feb 01, 2012Aspirant
RNWebGuard (Dansguardian) doesnt work
Hi Guys,
So I’ve been looking a for a proxy/filter add-on for the web and I found RNWebGuard (Dansguardian) on the community add-on site. So purchased the add-on only to find it had a dependency (hacked-off :oops: having not realised I would have to purchase that as well!).
So I figured I’m in already in so I decided to purchase the add-on for the add-on (if you know what I mean) and then find out it doesn’t work. The guide reads as follows, “After installation RNWebGuardConfig can be accessed by pointing your browser to http://ip.of.your.nas/dg-config/login.py or by clicking on the link provided in the add-on's section within the list of installed add-ons." This link provided in the add-on section doesn’t exist so I used the link, "http://ip.of.your.nas/dg-config/login.py" (I did change the part to my ip saying "ip.of.your.nas" to my ip just to get, "Not Found. The requested URL /dg-config/login.py was not found on this server."
The article also says make sure that Python 2.6 is installed first which I didn’t do, but I uninstalled RNWebGuard and then installed Python 2.6 and then installed RNWebGuard, with no joy.
Have I blow it by doing the install in the incorrect sequence? Have I missed something? I’m not to sure where to go from here, can anyone help please?
Thanks
Links below for articles:
http://readynasxtras.com/readynas-x86-a ... bguard-x86
http://readynasxtras.com/readynas-x86-a ... config-x86
http://readynasxtras.com/readynas-x86-a ... hon-26-x86
Thanks
- WhoCares_MentorPossibly something went wrong on the install of one of the add-ons. This normally should not break anything except for the add-ons in question. The first thing to try would be to re-install Python and the WebGuard config add-on without uninstalling the versions you already have installed.
-Stefan - Silversurfer79AspirantHi Stefan,
No love, I have the following add-ons installed to: Nas Mon, PHP5, Python2.6, ReadyNAS Photos II, RNWebGuard and Transmission.
I'm expecting to see a launch button for the site link of sorts like with NasMon or Transmission, I don't even know what the port number the product uses. Squid gave you this info on the add-on itself (had squid installed up till day before I installed this).
Ive drawn a circle where I'm expecting to see a button of sorts.
Transmission button like this.
Thanks for the help. - WhoCares_MentorWel, I could have a look using TeamViewer or you first try the other add-on I just posted on Twitter ;) Choice is yours.
-Stefan - Silversurfer79AspirantCheers, love Privoxy! Installing now.
PS.Im in the UK and i assume ur in the USA - WhoCares_MentorActually I'm just a few hundred miles south of you ;)
-Stefan - Silversurfer79AspirantWorks perfectly!
The only thing is i cant customize it with the p.p as it doesn't load, not sure I may have been to hasty or if it need to build.
Having said that its just started working after I enabled the proxy on my browser. I did a quick Google and found the default port 8118.
The link which references the "More..." ReadynasExtras doesn't resolve anything, I'm assume that's a holding page.
Thanks for the help, would should I do about RNWebGuard that I purchased?
Thanks again - WhoCares_Mentor
Silversurfer79 wrote: Thanks for the help, would should I do about RNWebGuard that I purchased?
Well, you didn't, did you? ;)
-Stefan - Silversurfer79AspirantThanks, i have! Much appreciated!
No content to show
