eton
Nov 16, 2012Luminary
RSS for Transmission add-on?
Is there some possibility to get RSS functionality with the Transmission add-on?
Mr_B
Mar 11, 2013Guide
Transmission doesn't use port9091, it's listening on that port for connections to the command interface. The actuall torrent trafic takes pace on a range of ports defined in the settings.json
If you want to change the ports, for transfers, or controll interface, it's a matter of changing those settings in the .json, just turn transmission OFF first. (In Frontview)
B!
B!
