Cledus
Dec 27, 2011Aspirant
rutorrent and security
Hi! I have installed rutorrent and PHP5 5.3.8. Everything works fine but I'm a little concerned about security. There is no login in to the rutorrent interface and there is allot of php stuff insta...
bbaraniec
Dec 29, 2011Luminary
Yes, it's gonna secure web interface only. I'm not using php on Nas myself nor using Torrents.
Security holes are being found on daily basis in more sophisticated software then php bittorrent client. Use strong password, forward only services that you need, use SSL and you should be fine.
