zom414
Nov 16, 2010Aspirant
SABnzbd Folder Help Required
I have installed both Python and SABnzbd (latest versions) on my NV+ and set it up. However, I'm having trouble with my folders. I have created the following folders: /c/media/sabnzb/complete /c...
arcturus1
Jul 25, 2011Aspirant
easiest thing is to just change the folder permissions through SSH. Basically just SSH into the box, go to the media folder, and then type in 'chmod -R 777 Downloads' type that without the apostrophes. This will change permissions on the Downloads folder to everyone, and recursively change permissions on any other folders/files in the directory. I had the same issue, so I just did that and it works fine now.
